Just bought a pretty old 12' aluminum boat and trailer for a fixer-upper. This thing is quite a mess, no wood seat tops and seat frame tops are bent. Hull appears in good shape.
My question is this...I want to put flotation in the seats(3) but don't know if I should use poured foam or the blocks. I also read where the flotation should be only at the top of the seats. Wouldn't think that should be to hard with block foam( just glue it to the bottom of the wooden seat?) Is there a certain type of block foam to use and how thick should it be?
Also, if I put a floor in the boat,should I not put any flotation under the floor? Read where it would cause the boat to flip upside down if filled with water. Any help would be greatly appreciated. Thanks in advance.
....John
....John
