Greetings All,
I have a 93' Johnson 15hp outboard that has been running strong for the last 2 weeks... It rained like crazy yesterday and after it all subsided I thought I'd go take a ride.
The motor turned on easily (as usual) but I noticed white smoke. Figured it was water just burning off and would go away... After about 30 seconds, the motor shut off and never looked back... I cranked and cranked and could not get it started.
I have already checked the fuel for water and it looks fine. I checked all the hoses to make sure that there is no air in the lines, and that seemed fine too. I did notice that my bulb was losing pressure and the connector that goes from the hose to the motor was leaking. I cut the tip off and reconnected it then played with the connection to see if I could keep my pressure and I did... Tried to crank again and NOTHING!
Anyone have any other suggestions?
