  #1
Old November 10th, 2008, 10:25 AM
Nautique93 Nautique93 is offline
Default Mercury 70 engine bog/ loss of power
starts and idles fine, will run wot for a few minutes then lose power all the way down to idle, and will stall unless you take it out of gear. when it stalls it will start straight back up, will rev in neutral, idle in gear but give it some revs and it bogs down. seems like it happens once the engine warms up. the engine has good compression- 135 psi on each cyl. I have tried squeezing the primer bulb while the engine is bogging and it makes no differnece- although after squeezing it once it stays squeezed until you come off the throttle- so i assume the pump is sucking enough? The engine is a blueband early 80's 70 HP
  #2
Old November 10th, 2008, 12:01 PM
Laddies Laddies is offline
Default Re: Mercury 70 engine bog/ loss of power
Your problem could be a couple different things, heat from the imp or a sticking popit valve if so equipped thats bad, I can't tell from here with out a serial number or a lean mix from a partially plugged high speed jet.
  #3
Old November 10th, 2008, 01:36 PM
S/N is 9353189. i am in the UK and havent managed to find this serial on any of the lists. The engine doesnt seem to get hot- it has a good stream of water that is slightly warm to the touch and the temp guage shows about 100 degrees. i have taken the carbs apart and cleaned them- i found little hard black deposits that crumbled to powder between the fingers- not sure what that was- if its any help. ran the engine again and no change.
  #4
Old November 10th, 2008, 01:50 PM
im assuming 'imp' means impeller? Also what is a popit valve?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1983 115 mercury outboard loss of engine power please help!! rick wiles Mercury 4 October 7th, 2008 11:32 PM
1979 Evinrude 70 surge in power/loss of power huntingjustinlouise Johnson & Evinrude Outboards 6 April 8th, 2006 05:36 PM
70 hp Johnson power loss wasteman Johnson & Evinrude Outboards 3 May 18th, 2004 08:07 AM
79 johnson 70 h power loss jstart1 Johnson & Evinrude Outboards 2 July 8th, 2003 04:08 AM
Loss of Power .....70 VRO babes@sledbabes.com Non-Repair Outboard Discussions 9 August 4th, 2001 09:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
