I have twin 140HP Suzuki 4 four stroke engines one runs greats the other started sputtering in and out at wide open throttle a couple of weeks ago and now it is doing it at lower RPM ranges. Both the engine are running from the same fuel tank. When I first started having this problem I fiqured it was a fuel filter problem so I replaced the Racor filters and still had the problem. Decided to replace the low pressure filter and high pressure filter still have the problem. I boat the boat used in VA last winter and they had not yet switched over to E10 fuel down there, and when I brought the boat back up to NJ it got fuel with ethanol. When I replaced the Racor filters there was a lot sediment in the bowl. Today I brought the engine up to about 2500 rpm and it was surging between about 1800 rpm to 2500 rpm. Anybody have any suggestions on what to check next?
