  #1
Old November 9th, 2008, 08:24 PM
viking96 viking96 is offline
Default 2002 Yamaha 115TLRA will not idle
Boat motor will not idle without hitting the electric choke every few seconds. Runs fine from one quarter throttle to full throttle but I have to take my time getting it up to or it will stop (I used to be able to hammer the throttle from idle with no problems). I checked fuel filter, replaced spark plugs and added a can of Sea Foam to gas tank. I’m thinking it has something to do with the fuel pump.The motor is a 2002 Yamaha 115TRA 2-stroke with 200 hrs. Any suggestions would be greatly appreciated.
  #2
Old November 9th, 2008, 10:28 PM
cousinabe's Avatar
cousinabe cousinabe is offline
Default Re: 2002 Yamaha 115TLRA will not idle
sounds like a bad fuel pump or dirty carb.
Fuel pumps are good for three years and then should be replaced.
http://www.boats.net/parts/search/Ya...201/parts.html
  #3
Old November 12th, 2008, 08:00 PM
Installed new fuel pump and still have the same problem. It could be the carb but I noticed something today. My gas tank vent (at least I think it's a vent) on the side of my boat is broken. It happened a few trips back when someone jumped on the boat when it was too close to the dock. This problem with the boat not idling started right after that trip. So, I'm thinking it has something to do with that. After it broke the hose fell and got wedged in between the foam in the haul. I haven't tried fixing it yet because I want to know if it has a filter of some sort that could be clogged. Anyone have any suggestions. The boat is a 2002 18ft Sailfish model 188CC. Thanks for your help.
  #4
Old November 12th, 2008, 09:20 PM
BaileysBoat's Avatar
BaileysBoat BaileysBoat is offline
A restricted vent could cause this, pulling a vacuum in the tank and restricting fuel flow. A collapsed primer bulb would indicate this. Their is a screen to filter air coming into the tank.
__________________
Stanley Islander 19, Yamaha F150
  #5
Old November 13th, 2008, 12:09 PM
douglloyd douglloyd is offline
Fix the vent ASAP but what your describing is a classic clogged low speed jet(s) in the carbs.
Have them pulled and cleaned or do it yourself.
Have you replace the thermostats lately? The engine needs to reach operating temperature to idle correctly.
Money is on the carbs though.
  #6
Old November 27th, 2008, 12:03 AM
Thanks to everyone for taking the time to help me with this. Had a mechanic look at it and it was in fact the carb. Needed to be cleaned and rebuilt. They also added a water fuel separator and said it would help keep the carb clean. Mechanic told me to not go more than 1 month without starting motor and letting it run for at least half hour. Also said I needed to add the Yamaha fuel stabilizer and NEVER to add Seafoam. Runs great now!
  #7
Old November 27th, 2008, 01:49 AM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
the yami fuel stabilzer is useless!
use seafoam and ringfree or chevron gas
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #8
Old November 30th, 2008, 09:15 PM
mjxlange mjxlange is offline
Thumbs up Re: 2002 Yamaha 115TLRA will not idle
After I rebuilt carbs, replaced fuel pumps,lines,filters it turned out that the idle adjustment had backed out a few turns reset the screw put some lock tight on it and now it runs like a champ.
  #9
Old December 1st, 2008, 10:06 AM
So the Tech who pulled and cleaned the carbs didn't check the idle screw first?
Well I'm sure the other items were due also.
If you ask Santa for a shop manual it will be a very useful gift for next year!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2002 Yamaha 150 HPDI Dies on Slow Idle holmesge Yamaha & Suzuki Outboards 3 July 24th, 2008 07:33 PM
2002 Mecury 75HP 4-Stroke won't Idle CGRLCDR Mercury & Mariner Outboards 1 July 20th, 2008 01:12 PM
Yamaha 2002 115hp 4-Stroke - Question At Idle Speed gearyg Yamaha & Suzuki Outboards 6 April 27th, 2008 07:53 PM
2002 90hp johnson idle? seantim Johnson & Evinrude Outboards 9 July 14th, 2007 11:19 AM
2002 Yamaha 150 Idle Problem - PLS Help! ez rider Yamaha & Suzuki Outboards 4 April 10th, 2007 07:01 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
