  #1
Old November 9th, 2008, 07:26 PM
captjohnr captjohnr is offline
Default 2005 yamaha f75 belt noise
I Have A 05 F75 Yamaha,it Only Has 60 Hrs On It . I Bought It
New In 06. It's On A 20ft Flat Skiff It Makes Belt Noise Just Like
A Drive Belt On A Car??? It,s A Of And On Thing Mostly At Low Idle
And Mid Range Again It Don't Do It All The Time. I Have Pulled The Cover And Inspected The Belt And There Is No Ware At All??
Thanks In Advance For Any Help!!!!!
John R
  #2
Old November 30th, 2008, 09:35 AM
rusdad rusdad is offline
Default Re: 2005 yamaha f75 belt noise
The rubber gromet on top of the water pump can get dry sound exactly like a slipping belt.
If you drop the leg of and put some grease on the shaft under the gromet your noise may dissapear.
  #3
Old December 5th, 2008, 09:28 PM
Motorlady's Avatar
Motorlady Motorlady is offline
Piece of cake, I had to sign up here just so I could respond to you. Remove the lower unit & your will see the drive shaft. Grease the drive shaft splines with special No. 630-AA or otherwise known at W2 grease. Usually comes in a yellow tube. We have had some of these engines & they were doing the same thing. Our Yamaha rep came in & suggested this as a repair & it worked well. Lack of lubrication. You will most likely fine your issue gone. If it still remains, then check it in with a certified Yamaha repair shop....you have other issues. Andrea
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2005 115 yamaha 4 stroke squeaky noise happonen Yamaha & Suzuki Outboards 6 July 23rd, 2009 09:43 AM
Yamaha F75 Trim/Tilt Indicator kathys1guy Yamaha & Suzuki Outboards 3 July 21st, 2009 07:00 PM
Belt Noise on Mercruiser 260 eriefeelin Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 May 26th, 2007 02:39 PM
04' Yamaha F115 Belt noise? jrsnyder79 Yamaha & Suzuki Outboards 1 July 6th, 2005 04:25 AM
Belt noise? sinkswim Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 July 5th, 2005 09:29 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
