I just pulled the plug on the foot to drain gear lube, Found metal shavings on magnet, Lube solid Black, When i turn the prop you can hear something on the inside, is that normal???
Also when i put bottom plug back into and started putting new oil in the oil seemed not to take, it just kept coming out the hole and not going in the case.
The motor had sat up for ten years never been run since then, til a few months ago, should i get foot rebuilt??
