  #1
Old November 9th, 2008, 12:17 AM
suddendebt suddendebt is offline
Default f225 yamaha stalls on acceleration
I have an 05 yamaha 225 fourstroke.
It ran perfect till it sat a few months. Took it out and wouldn't get over 2500 rpm. then as it sat a few minutes it rose a few. after starting it and stopping it over a coupe hours, it finally took off. I figured bad gas and injector cleaner fixed it. Recurred last weekend. never really got better. Took out all old gas and knocked out the antisiphon valve on the tank to ensure no restrictions. Idles and starts great. In neutral it revs as high as I want flawlessly. Any comments???
  #2
Old November 9th, 2008, 03:44 AM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
Default Re: f225 yamaha stalls on acceleration
any motor will rev fine in neutral
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #3
Old November 9th, 2008, 07:57 PM
Really???
I suppose I was just trying to give as much info as possible to avoid having people who were concerned with a valuable suggestion from having to ask if it runs like junk all the time.
  #4
Old November 9th, 2008, 10:35 PM
cousinabe's Avatar
cousinabe cousinabe is online now
I am assuming you have the 2005 F225TURD model...
you may want to check the VST filter... item#18. This is a high pressure pump filter.
you may also want to poke around the other fuel/injection pump diagrams to gain some knowledge.
http://www.boats.net/parts/search/Ya...201/parts.html
  #5
Old November 9th, 2008, 10:52 PM
sdsaw sdsaw is offline
I don't know if this will help you, but I was following a thread from another board about a Honda 130 EFI with similar symptoms and this is a what was causing his problem
"I mentioned the missing Honda outboard and described the symptoms and he goes, "I know exactly what it is". He came over the next day and pulled out this little solenoid switch that controls air flow while the motor is at idle. The thing has a little screen in it and it was all clogged up. Cleaned it up, put it back on, and she is good to go - running perfectly! She hasn't stalled once since."
I'm sorry, I don't know exactly what the part is called but I'm pretty sure that your Yamaha has one also.
...Or, dirty injectors?
Hope you get it fixed, Scott
__________________
"Somebody put salt in the ocean to punish us boaters"
1989 22' Bayrunner Cuddy (Aluminum)
2001 Merc. 115 Saltwater Series Fourstroke
1988 Yam. 9.9 High Thrust Fourstroke
1998 Dodge 2500/ 24V. Cummins diesel
  #6
Old November 10th, 2008, 02:39 PM
JUSTINTIME's Avatar
it could be the electrical fuel pump
plug it into yds
__________________
  #7
Old November 10th, 2008, 09:04 PM
You guys are awesome. Thanks Cousinabe for the link to the diagrams. Wow A picture is worth everything. Wife wouldn't wait any longer so I dropped it off for the pro's to work on. I'll get back when I know what it was. THanks again guys.
  #8
Old November 18th, 2008, 10:26 PM
Dealer says it's just dirty screens on the fuel filters. Pumped some cleaner in and set 2 hours then BAM. Good as new.
  #9
Old November 19th, 2008, 12:55 AM
Wow, that was easy!
Which filter screens were dirty?
Couldn't have been the in-line, see-through fuel filters. I would think that those would just be replaced.
VST filter screen?
Thanks
__________________
  #10
Old November 19th, 2008, 01:51 PM
JUSTINTIME's Avatar
well what you cleaned went to the injector screens
keep running the cleaner all the time
__________________
  #11
Old November 19th, 2008, 06:55 PM
Gunk was supposed to be from water and cheapo gas. Will be putting a 10 micron filter/separator in to get out more junk.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercruiser 140 - stalls @ acceleration helqud Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 16 July 20th, 2009 11:34 AM
Stalls on idle and acceleration Bob95 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 August 12th, 2008 10:27 PM
Yamaha excel225 stalls at first acceleration rovsub Yamaha & Suzuki Outboards 2 May 9th, 2007 10:54 PM
BF90 Stalls on hard acceleration Sandiford Honda & Tohatsu/Nissan Outboards 9 April 25th, 2006 05:01 PM
70hp Johnson, stalls on acceleration Clint F. Johnson & Evinrude Outboards 9 May 16th, 2004 03:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
