Quote:
Originally Posted by Laddies
Thanks for the info, somebody stated that someone else placed it on the line and that was useless, sorry to say but lower "filter/1" (a connector) according to spare parts manual is a check valve connector, if you remove and fill connector with gasoline and blow both passages, just one will let gasoline out. When you open external fuel cock valve, gasoline from internal tank will flow to filter 2, but connector 1 will block any gas also flowing to the main hose connector and spilling through it if you ever happened to have a faulty one. Have checked it personally and works that way.
Happy Boating
