I got it ruining after years of sitting! Someone told me to start the top needle at 1 1/2 turns out that doesn't work. If the throttle is all the way down it will shut off? Maybe it is int warm enough its just in a barrel of water. What do you think I can get it to run somewhat smooth with the throttle up a little but i don't think it would be good to shift at that idle?
Thanks Matt
Cleaned fuel pump, carb, new coils points condensers plug weirs kill switch harness ext. It played with the needle all over the place but it still happened?
Thanks Matt
