Re: 2002 50hp Mercury solenoid
You can test the sol by checking the sol coil continuity. If it's open then, I would say I would say the sol is bad. You can back check yourself, have a helper turn the key switch and check to make sure you have 12 voilts at the sol. When you try to crank it that well tell you for sure. If you don't get the 12 volts then you need to look a little deeper. Safety switch could be breaking the ground to the sol. So you need to check for power at the sol, if you have 12 volts to ground and not on your sol look at your safety switch.
I hope this helps
__________________
Hamit
BT1 USN ret
