  #1
Old November 6th, 2008, 04:38 PM
dalton565 dalton565 is offline
Send a message via MSN to dalton565
Default Installing wakeboard tower
hey guys
im currently searching for wakeboard towers for my boat. Im looking for a tower, 2 racks, and a mirror the best price ive got so far is just over $1000 for the lot the tower is a camellion. it looks good
The problem is installing, the best price i can get to install is $500, i would be willing to try installing myself, has anyone any expeirence installing their own.
My boat is an 18ft campion 545i w/4.3ltr inboard 8ft beam
  #2
Old November 6th, 2008, 08:44 PM
Jon D Jon D is offline
Default Re: Installing wakeboard tower
I dont have experience but i watched them install my tower and they had to really secure it strongly and i was surprised how far down they went to secure the tower in the floor. and how access the sturdiest part of the boat . I would suggest if not too familiar with what you want to have done get it professionally done. It was a lot more in depth then i thought they were going to do and i was glad i had it done professionally with warranty
  #3
Old December 4th, 2008, 10:47 PM
Sea Ray Sea Ray is offline
I have installed a Monster Tower on my own boat (1999 210 Sea Ray Open Bow).
Probably the hardest part for me was figuring out where I wanted to mount it. They are very universal so your options are almost limitless. Make sure you have adequate head room, the windshield door still opens and closes, the bimini top or convertible top will still fit, you have access to the bolts where the mounts will be located, it fits in the boat when folded down and the legs are within the given range suggested by the tower manufacturer.
Sea Ray boats are well built which made my installation easier. The fiberglass is thicker than a lot of boats but I still used a 3M marine grade adhesive and glued reinforcement boards (1/2" thick treated plywood) under the boat where the mounts went. Make these boards as big as you can and round the corners so they aren't cutting in to the fiberglass. I used 1/2" so there would still be some level of flex to the board as to distribute the load out a little better. I thought 3/4" would be too rigid.
Mark all the holes carefully, double - triple check your measurements. The second hardest part was getting the nerve to drill holes in my perfectly good boat . Drill slow and with the drill in reverse, countersink the holes to relieve the stress to reduce the chance for the gel coat cracking.
If you add reinforcements boards underneath, allow a couple of days for the the glue to cure before using it. When you do start using it, keep checking the bolts to make sure they are staying tight. You should tighten them about every 1/2 hour to hour the first time you use it.
All in all it wasn't as bad as I thought it would be, but I guess that all depends on how handy you are and what difficulties your particular boat presents in mounting.
Good luck and feel free to PM me if you would like any more info!!
  #4
Old December 5th, 2008, 01:31 AM
QSS QSS is offline
i own Queensland Skiboat Sales in Queensland Australia and are a monster tower dealer we fit monster towers to lots of differnt boats. they are quite easy to fit probably the easiest on the market. Yes check and double check your measurments and get it centred properly. we encourage to have them done profesionaly as we cover any warranty issues. in saying that i think we have had 2 warranty issues in the last 8 years of trading. the most important thing is to make sure your hull is reasonably fat around the parts where the feet of the tower are. if your doing it yourself have it slung up in the air bolted together and lower down onto the boat marking the two front legs 1st then go from there. good luck.
  #5
Old December 22nd, 2008, 07:15 PM
Superb advice guys as always
i have just ordered all my stuff tower, racks, lights even fat sacks all should be here week after christmas then me and a few friends are going to attempt to install.
Im going to seriously take my time, measure and measure again before drilling. We should be able to build the tower up and susupend it above the boat via ropes to make sure it is located right, then mark and drill. i will take pictures of progress and post the results.
Stay tuned.
  #6
Old January 9th, 2009, 07:38 PM
Good News !
Installed the tower myself, took about 11hours and there was 2 of us. Took our time as it was the first effort.
Check the pictures
http://gallery.highclarity.co.uk/main.php?g2_itemId=29
page 1&2
No real issues, havent tested it out yet, will be a few months before it heats up. So watch this space. Anyone else after advice pm me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Installing a Wakeboard Tower - Help! Geo2008 Wakeboarding 5 August 7th, 2008 02:38 PM
Installing Wakeboard tower, safe? 4winnsskipper Boat Topics and Questions (not engine topics) 9 March 17th, 2008 10:06 PM
Installing a Wakeboard Tower...MD area. jwharan Boat Topics and Questions (not engine topics) 1 September 15th, 2005 08:04 AM
Wakeboard tower summit1 Boat Topics and Questions (not engine topics) 20 December 7th, 2004 05:33 AM
Wakeboard tower trweber Boat Restoration and Building 0 June 19th, 2004 07:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
