  #1
Old November 6th, 2008, 04:14 AM
reelfishin reelfishin is offline
Default '65 Mercury 850 inline 6 lower unit?
I picked up a boat the other day which was garage kept for many years, probably since new. The boat was parked after the lower unit seized many years ago. I pulled the lower unit, and gave the motor a good once over and a compression check. All looks good.
Now for the question, I have a few good used mid to late 60's Mercruiser lower units that sure do look the same other than the drive shaft. The lower units were all from Merc 110 and 120 I/O drives.
Can I swap drive shafts and use one of them on this motor?
The prop hub and housing diameter is the same, the bolt pattern looks the same, and the shift linkage is the same. I guess the main question would be gear ratio and the ability to install the outboard drive shaft in the I/O lower unit?
  #2
Old November 8th, 2008, 06:29 PM
hamit59 hamit59 is offline
Send a message via MSN to hamit59
Smile Re: '65 Mercury 850 inline 6 lower unit?
Well the case could be the same but the ratio will not be. That would likely 1:1 as the ratio is set on and i/o in the upper. one on e bay you have all winter i have seen them on there before. there's always criegs list. I have found a lot of parts motors on there also.
__________________
Hamit
BT1 USN ret
  #3
Old November 9th, 2008, 12:40 AM
Default Re: '65 Mercury 850 inline 6 lower unit?
If the case is the same, that may be good enough, the case on the 850 is pretty well worn and pitted, the I/O cases are are all mint.
I've been told by several sources locally that they swap with no problem and by others that it's a no go. I know it will mount up and use the same prop. It's the ratio that will be the issue. I can change prop pitch, and a higher ratio may not be a bad thing since this motor is on a super light boat. I may be able to make even better use of the torque from the inline 6.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Merc 1972 140hp Inline Six lower unit compatible with 1968 125 inline six? lilboatsman Mercury & Mariner Outboards 4 May 17th, 2008 04:08 PM
Lower Unit for Mercury 850 Rakman Mercury & Mariner Outboards 3 June 7th, 2004 08:10 AM
Lower Unit for Mercury 850 Rakman Non-Repair Outboard Discussions 1 April 27th, 2004 12:07 PM
Mercury 850 Thunderbolt (85hp) What is the correct Lower Unit for this model? fomoco-gnatsum Mercury & Mariner Outboards 3 August 22nd, 2003 07:16 PM
Lower Unit Swap Merc. 850 using 65hp lower fomoco-gnatsum Mercury & Mariner Outboards 0 August 11th, 2003 08:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
