Outboard ... charger problem 8hp Honda
Donnacha
Hi I have a new Honda 8hp and cannot get any power from the 12V outlet to power the fishfinder, Q. must I have a battery connected with a min charge before the power regulator kicks in? Thanks D
kandil
Re: Outboard ... charger problem 8hp Honda
Check the fuse inside the cowling cover it is in a black tube to the left if you are standing at the Handel and you cannot power any thing directly it is for charging the battrey.not to run any thing
