Yamaha 40cv 2 stroke 3 cyl 2006: rpm and alternator output frequency
sandro
Hi,
I need to calibrate a tachometer which has a potentiometer to adjust the rpm scale, so I thought to use a frequency meter connected in parallel to it...
but which is the correspondence between RPM and Hz?
Thanks a lot.
Silvertip
Honorary Supreme Mariner
Re: Yamaha 40cv 2 stroke 3 cyl 2006: rpm and alternator output frequency
6Hz/Rev
sandro
Do you mean: 1 crankshaft revolution in 1 second = 60 rev in 1 minute = 60 RPM = (60x6) 360 Hz
so...
at minimum 700 RPM = 4200 Hz
2000 RPM = 12000 Hz
5500 RPM = 33000 Hz
