Where do these wires go? (4.3 merc)
Dante04SRT
I opened the cover on the 'new' boat and noticed two wires that weren't connected. Any ideas?
One is gray and the other is brown...
Uraijit
Banned
Re: Where do these wires go? (4.3 merc)
Is your trim sensor working (brown)? How about your shift interrupter?
achris
More fish than mountain goat
They look like ground wires to me... Spares in the harness... Just throw some insulting tape around them and tuck them away neatly...
Chris......
Dante04SRT
Tilt/Trim gauge is iffy.... haven't noticed it really working because my tilt/trim control has somewhat confused me... [see other post] :)
Uraijit
Banned
By "iffy" you mean it works intermitently, or do you mean that you don't know?
If the gauge is working at all, then that's not what the brown wire's for. :D
Dante04SRT
I mean I've seen the gauge move but I can't say its accurate. It doesn't seem to move quickly in relation to the drive. When the drive is all the way up or down is when I notice it - I've never seen it work in between.
achris
Trim gauge and interrupter wires have insulated bullet connectors, not ring connectors... They are unused grounds...
Chris..........
Uraijit
Banned
Grounds in multiple colors? Doubt it.
And that's a pretty broad sweeping statement that they're always bullet connectors.
Plenty of boats have trim gauges and shift interrupters that use screw connectors with termination blocks.
Dante04SRT
Does anyone have a wiring diagram for this motor? I'm curious if this has anything to do with the tilt/trim problem in my other post.
achris
Both leads are black... trick of the light makes it look lighter...
For an engine of that era... all non ground connectors are insulated or plug-ins... ONLY grounds are uninsulated rings....
Chris.........
Uraijit
Banned
I don't have a diagram for your engine, but this should help.
attachment.php
Uraijit
Banned
Chris.........
Trick of light eh? If you say so... ;) Funny that they appear as exactly the same colors in both pics, and the OP hasn't mentioned (despite mine and his specification of colors) that they're anything but brown and gray.
achris
Post your engines serial number or year and I'll post a wiring diagram........
Chris........
Dante04SRT
Chris........
I'll have to get it tomorrow - Its dark and the boat's under the cover for the night.
Thanks!
As for the colors, they are definitely gray and brown.
Dante04SRT
I did notice tonight there were two wires with the covered connectors on them, that weren't connected to anything else. They were under the dash area. I'll have to take a pic. If the tilt was wired with the trim (bypassed) would the trim up button still work?
achris
.... If the tilt was wired with the trim (bypassed) would the trim up button still work?
Yes.... As long as there is a jumper link (wire) in the place of the limit switch...
Chris......
Ed R
Wow! you guys are good, in that year the 4.3 was offered with EFI, etc. Mercury used same basic engine harness on the early models. nothing to be worried about !
