  #1
Old November 4th, 2008, 03:04 PM
scottrn scottrn is offline
Default 4.5 Mercury starter (pull) wont engage
Hi guys, I just picked up a nice little 4.5 Mercury. I haven't dug into it at all yet but I did notice the pull starter is mounted in the top cover and when you pull it the little teeth that ought to come out to engage the flywheel don't move. All parts move freely, just no engageing of the teeth. Can I 'denastify' the assy intact? It looks gunked up with some thick grease. I'm afraid to disassemble the assy because the coil spring might go flying then I be in deep for sure! It sat for about 2 years but had no problems prior to that. Also, where would I go for a manual, and what brand is recommended?
Thanks much,
Scott
*EDIT* I'm at work so no numbers but I will post them when I get home tonight. I'm guessing 74-75 due to the blue stripe.
  #2
Old November 4th, 2008, 05:23 PM
Laddies Laddies is offline
Default Re: 4.5 Mercury starter (pull) wont engage
That is a common problem with that type starter, the grease gets hard and prevents the friction plate from engaging the dogs. Use most any type of solvent and remove as much of the hard grease then lube it with oil or lite grease and you should be good to go.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Starter just spins and wont engage. Gradivus Johnson & Evinrude Outboards 7 August 9th, 2008 04:23 PM
Starter wont engage, just spins stoked not Johnson & Evinrude Outboards 11 June 25th, 2004 10:54 AM
Force 40HP starter wont engage Jparen Force & Chrysler Outboards 3 August 26th, 2003 05:55 AM
starter gear wont engage flywheel brockw Johnson & Evinrude Outboards 4 May 26th, 2003 10:47 AM
motor won't engage to pull starter. djsmitty88 Mercury & Mariner Outboards 3 June 5th, 2001 03:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
