  #1
Old November 4th, 2008, 01:05 PM
DanS7 DanS7 is offline
Default 16ft Avenger project
Hey Guys,
I was either in the right place at the wrong time, or verse visa, and picked up a 16ft Cee Bee Avenger with a 90hp Force for $300. It needs a total restoration, but appears generally sound, so I’m starting in on this as my winters project. I am also starting out (as a big boat mechanic) being a bit naive about ski boats in general, and Avengers in particular. Can you guys enlighten me on a few topics, and help with my learning curve? I’m trying to get ready for another Labor Day bash - days of boats and babes at Crescent Bar on the Columbia River, and nights of DMB at the Gorge.
Half an hour of sleuthing on the net tells me that Avengers are generally well regarded. My tag says m/n 160, s/n 739, made in Bellflower, CA. Any idea what year mine is and the history/lineage of this model? I have yet to hear back from the factory, now in Lynwood?
I am starting the rebuild process on the Force outboard. I’m told that this is an acceptable motor for this boat, pushing it to 60ish mph. I’m not after ultimate speed, just a good reliable engine I can have some fun with. Actually the fun for me is the whole boat restoration process. Any opinions?
What is normal for fuel tanks for this type of boat? There is an (unused) fuel fill cap on the motor well, so apperantly there was a built-in tank at some point? The previous owner used it as a work boat, and used 5 gal jugs. How much fuel should I plan on for a day at the lake? My current thinking is to do a wraparound bench seat in front of the motor well, and stash jugs underneath. And probably cut out the floor under the seat all the way to the transom. Is there a need on these boats to get fuel/weight forward to get the bow down? Any thots?
Thanks, Dan
  #2
Old November 5th, 2008, 04:38 PM
Chris1956 Chris1956 is offline
Default Re: 16ft Avenger project
Dan, I have a '74 16' Avenger. I run a Merc 135HPV6 on it, but up until last year I ran a merc 150HP inline six. The Inline was about 100# lighter, which was probably better, it tends to take waves/wakes into the splashwell now, at low speed. I have an 18 gal built in tank under the bow. It is a standard flat tank from Moeller, and fits well. It sits on a plywood platform someone (before me) built. I recommend at least a 12 gal tank for you.
The back of the boat is a bit low, so you may not want to put a bench seat in the rear. Two folks sitting and someone else walks back there you might start taking on water. I have two back-to back seats.
BTW - with that 90HP force, expect to see no more than 45-50MPH, but only if you have power trim. It takes a lot of power to go faster than 40MPH, even in an Avenger. My 135V6 will allow me to cruise at speeds in the low 50s. Max speed is probably about 60MPH, although I haven't tried that too ofter. I run a 21" pitch Rapture prop, but might be able to spin a 23" pitch prop.
Also BTW - At full speed (55+MPH), I need to hold the boat very steady or it will chinewalk. However, at 50 MPH it rides rock steady. With the inline six motor the boat was slow to plane, and then would really accelerate. If you did not reduce throttle when the tach hit 3000RPM, the skiier would be launched out of his skiis. This is also the time when the boat would "get away" from a new driver. They were unable to cut throttle while steering, and the boat would hit 50MPH petty quick and scare the heck out of them. The V6 motor has consistant power all the way up the power band. it is not nearly so scary.
You might do a search on the web for the original brochure for your boat. I found the one for my boat, by matching up it's apperance. The newer Avengers had the "Bubble Decks".
  #3
Old November 5th, 2008, 04:42 PM
Dan, One more thought. I have never had trouble keeping the bow down. I would think a bow lifting prop would be the way to go, if you can get one for that motor. You might lift the engine on the transom also. I have mine on a jackplate and most of the way up. The antiventilation plate rides 3/4" above the water.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Avenger Project: NEARING THE END croSSed Boat Restoration and Building 3 May 14th, 2007 06:18 PM
Avenger Project - NEW PICTURES! PLEASE SEE! croSSed Boat Restoration and Building 6 May 10th, 2007 03:15 AM
Avenger Project - TRANSOM INSTALLQ croSSed Boat Restoration and Building 2 February 10th, 2007 07:22 PM
Avenger Project UPDATE croSSed Boat Restoration and Building 1 January 1st, 2007 06:12 AM
Avenger Project croSSed Boat Restoration and Building 6 December 29th, 2006 01:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
