ID Old Envinrude
kwoz
I have an old blue 15 Hp Fast twin with pressurized tank. There is a number on the inside of the cover-203739. Can anyone tell me the year? It runs well. Is it worth anything? thanks
tashasdaddy
Re: ID Old Envinrude
need number from plate under the front of the cover, between the mounting bolts.
tashasdaddy
in the pm you sent me you said it was a 15014, which is it?
wbeaton
15014 = 1955
15016 = 1956
Pretty important to know which one you have as the 1955 has a known issue with its lower crankcase seal.
kwoz
It is 15014! I have noticed that I need to add hypo oil to the lower uint every once in a while. Is there a fix for this problem??
Thanks
Keith
freddyray21
either new seals in the lower unit or new washers. Under the fill plugs are washers they should be changed when you change the lube. If not they will often leak.
wbeaton
Thanks
Keith
Yup. You need a seal kit. I have yet to find an original 50's lower unit that didn't need to be resealed.
tashasdaddy
personally, if you are just having to add, and it is not getting intrusion, i would run it, and keep checking it.
samo_ott
As strange as it seems I concur with that idea!
