alpha shifting issue help
karter2888
I have an older alpha with a 5.7 mercruiser. Boat was running great, shifting fine then all of a sudden it wouldn't come out of forward. I shut the engine off and it was in neutral started it up and it was in neutral, shifted it into forward it gos in fine then won't come of of forward. There is no reverse at all.
Any answers???
Karter
imported_TheMan
Re: alpha shifting issue help
Have you examined the shift cable? Performed the adjustment procedures?
If it was in forward when you shut it off and neutral when you restarted without changing the throttle position, it likely means that your shift interrupt switch is not activating at hte proper time, thereby not allowing the clutch to disengage. Make sure your cables are adjusted properly and properly attached.
karter2888
I put it in to neutral then shut it off. re-started it and it is in neutral shift into forward and it goes fine, shift it back to neutral and it stays in gear. turn it off with the shifter in neutral and it goes to neutral on the restart. There is no reverse at all at any time.
karter
Fishermark
With the engine off, and the boat on a trailer - can you maually shift it into and out of gear? Put shifter in forward and turn the prop counterclockwise. Does it lock into gear? It should "ratchet" when you spin the prop clockwise.
Do the opposite for reverse - shifter in reverse, then turn prop clockwise. It should lock in place, and ratchet counterclockwise.
Try that and post the results.
achris
More fish than mountain goat
Check for a broken shift cable... Either the one between the control box and the shift plate, or the one from the shift plate to the leg.. Either broken or the lock screw has come loose that holds the cable end to the inner...
Chris.............
JustJason
if there is no reverse at all your lower shift cable is probably bunked.
try disconnecting the lower cable at the bracket on the manifold, and see if you can put it into gear that way.
i'm surprised your engines not stalling though.... is the shift interrupt switch still hooked up or is it bypassed?
djvan
I read someplace that you shoudn't shift into reverse without the engine running. Something about damaging the lower shift cable.
DougV>
achris
DougV>
Have a member of the audience turn the prop while you shift it...
chris.......
karter2888
I took the lower cable off the plate and shifted it. It goes into forward and neutral but no reverse. I think the lower cable is NG. My local shop told me that the cables can stretch any one else had this problem?
Karter
achris
More likely the shift shaft seal has failed, let water into the shift slider cavity and the back of the cavity has filled with salty crap and won't allow the slider far enough back to select reverse...
Remove the leg. Strip the cable out, including the outer. Clean the cavity. Remove the failed seal and fit one of the new, updated ones. Fit new shift cable. Re-fit leg. Adjust cable as per the manual... Go boating :D:D:D
Even with a stretched cable, once it's off the shift plate, it should select reverse if the above hasn't happened....
Chris...........
karter2888
I pulled the drive and everything looks good. No salt the cable works free. Checked the drive it goes in and out of forward and reverse.
I guess the cable is just messed up i am going to replace it today and see how that goes.
karter
achris
Check for 'slack' in the shift system... Look at each place where two components come together... where the intermediate shift shaft splines into the lower shift shaft; where the upper shift shaft slides into the top of the intermediate shift shaft; and check the cable for slack between the inner and the sift slider on the end of the cable... Often each of them is not a great deal, but they add up and you can't get enough travel to shift gears properly...
I think the check procedure is in the manual...
Chris.....
