I rebuilt my 1987 125 due to a bad piston/bearings. And it has gone bad again after 5 minutes of running. So what do you think the problem is? I only have problems with that piston...the others look good. It looks like it is running extremely lean. The motor locks up after running at full throttle. It has little dropplets of water in that cylinder. Any ideas?
Could it be the reeds? They didn't look bad but...hmmm. If it was the top carb one would think both 1 and 2 would be bad. What should I do?
Thanks,
Curtis
Thanks,
Curtis
