  #1
Old October 30th, 2008, 02:13 PM
gbb gbb is offline
Default Stress Cracks
Looking at a boat tonight, the owner says it has 2 stress cracks. What are stress cracks and should I go look at the boat. Boat is a 13' Boston Whaler.
Please let me know what these are.
  #2
Old October 31st, 2008, 10:48 PM
huckelberry huckelberry is offline
Default Re: Stress Cracks
Stress cracks are cracks in the gel coat of a boat that let you know there is undue stress on a particular area or a problem under the gel coat. I have a 79 11ft Whaler and it is covered in cracks in the gel coat, but none seem to be wide enough to tell me there is a problem. They seem to be common on boats of that age. If it looks like the transom is about to fall off stay away, but if not, I'll bet you will have a hard time finding a boat with none.
  #3
Old November 4th, 2008, 01:03 AM
ebry710's Avatar
ebry710 ebry710 is offline
Ensign
If an owner calls cracks, stress crack, he is letting you know there is a problem. Where is the stress crack is important, but unless you are 1) a skilled boat surveyor or 2) the boat is cheap and you are not going to cause more stress, stay away. It takes a lot to break a whaler.
__________________
1987 Boston Whaler "Outrageous 18"
1989 Johnson 120 V4 VRO
  #4
Old March 1st, 2009, 11:43 AM
shes a keeper shes a keeper is offline
I just picked up a 17 foot outrage2 and there is stress cracks around the bow eye and i am concerned being anal that i would like to repair this my self,Did any one have this problem i think this happened when the boat was torqued down to tight.Also the bunks are not touching the hull
- thanks mark
p.s she is a 1999 boston whaler 2001 load rite traler
  #5
Old March 1st, 2009, 12:21 PM
ebry710's Avatar
Ensign
Quote:
- thanks mark
Welcome to iboats. Fiberglass is not hard to repair, but the term "stress crack" must be followed but what type of stress crack and how big an area. Pic are always good.
Do you think the bow eye is pulling out? do you think the boat hit something and that cause cracking? or do you think the bow was hitting the trailer while towing?
__________________
  #6
Old March 2nd, 2009, 08:24 PM
thanks for the reply.The boat bow eye is tight but for some reason there is small thin cracks around the eye.it is not hitting anything I noticed a 8 in hair line crack going down and i want to repair this before it hits the water line.I have owned two montauks and this never happened.This is my first 17 outrage maybe the gell coat is not a thick any thoughts ?????????????
  #7
Old March 3rd, 2009, 12:08 AM
ebry710's Avatar
Ensign
Without actually seeing the crack I can only give you "best guest" advise, but I would treat it first as a gel coat problem. My feeling is to repair the gel coat, watch it closely and see if it cracks again. I always like to do simple things first and then the tough stuff. If it is deeper then the gel coat it will crack again, not harm and not foul. In the meantime its sealed and you can get some use out of it. The Whaler hull is foam filled and it is hard to actually damage the fiberglass.
You will like the Outrage. It doesn't skip on top like the Montauk. Its hull allows for some cutting of the water.
__________________
  #8
Old March 3rd, 2009, 06:52 PM
thanks for the reply and I think it is a miner crack and I appeciate your opinion on the outrage <*)))-}
  #9
Old March 3rd, 2009, 10:02 PM
ebry710's Avatar
Ensign
How are you going to fix it?
__________________
  #10
Old March 30th, 2009, 08:14 PM
I usually clean out the crack and then use west system than gel coat and buff. But this outrage is real sweet and i will have to have someone look at her because I want the gelcoat to match perfectly.I have did older B W but I want this to look perfect.
  #11
Old March 30th, 2009, 08:19 PM
I will probably have someone do her only because I want her to look mint.I have fixed old B W and did ok with marine tex and gel coat from the whaler dealer to match but i do`nt want to do a ok job. mark
  #12
Old March 31st, 2009, 04:04 AM
ebry710's Avatar
Ensign
Keeping her mint is always the best. I have not brought my to mint, I am still working on function.
A perfect match on the gel coat color is always key. Outside of that, matching the surface sheen is more a matter of layers and sanding. I have looked at self-repair giving me a feeling of pride........but if I had the money, I would do as you, pay someone to bring her to mint.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hairline cracks! Are they gel-coat or stress cracks??? John the landlubber Boat Restoration and Building 13 August 16th, 2009 01:56 PM
How can you tell the difference between stress cracks and gel coat cracks??? Mjust Boat Restoration and Building 0 August 30th, 2007 11:19 AM
stress cracks Heller1 Glastron Boats 4 May 11th, 2006 07:28 AM
stress cracks handball Boat Topics and Questions (not engine topics) 18 February 29th, 2004 07:18 AM
Stress cracks / spider cracks peteua636 Boat Topics and Questions (not engine topics) 11 June 11th, 2003 08:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
