I have a 2001 Volvo Penta 4.3GL and the engine started to over heat. Took the boat out of the water and did a Raw water pump test. Found that the Impeller was no good. All blades from the Impeller was missing except for one. I found pieces of the rubber blades in the pump and in the thermostat housing but not all. My question is, how far do I need to go in finding these pieces. I believe I'm missing 4 blades out of 12. Will these flush out through the exhaust? Is there a way to finding these pieces without taking apart the engine? Any help would be greatly appreciated.
