Hey guys,
I was under the assumption that most mercruiser drive props were interchangable. (15 spline hub)
I have a 1978 Merc 470 with a One Drive and my current prop is a "48 7958044 25P" I need to go down to a 23 or so.
I borrowed a spare 21 pitch prop from a friend this weekend to see where my RPMs were at. When I went to install it, the hub length (main prop body) on his was 7"s. Mine is 6"s. His covered all the splines on my output shaft so I could not install it.
My dad has a Trophy Plus 4 blade on his 200 V6 Merc OB and his hub length is 7"s as well.
When I am looking for props, how do I determine what the hub length is? I do not remember seeing this information in my research.
Thanks for the help,
-Eli
-Eli
