Re: 1995 150 Evinrude Salt on the head bolts?
By now the internal anode on the prop shaft bearing carrier will be useless and you will be depending on the anode in the cut-out space on the top of the gearcase. It must be kept in top shape and tested frequently with an ohmmeter for continuity.
There is an anode on the transom side of the midsection that should be kept in good shape as well.
I would make cleaning the bolts and the area around them a priority.
Whenever possible, you should try to flush the motor with Salt-Away.
In a salt environment, be sure to frequently grease the rams on the T&T and steering with Triple Guard grease, and withdraw the rams completely whenever possible.
