camawelander
- Jun 4, 2008
- 34
hello- I have a 1989 force 35 model #357F9A - this motor is in mint condition, not a scratch, super clean, always maintained, starts right up, and runs like a top...
For the first time I dropped the lower unit and attempted to change the impeller. Everything seemed to go smooth. I had to tap the seal retainer off of the top of the drive shaft to remove it so that I could slide the old impeller off. I noticed that the driveshaft spline seal was a bit worn, it looks like a boot that hold that keeps the grease on the upper drive shaft splines. Is this rubber boot necessary to re-install if this motor is only run in fresh water? I had a local mechanic tell me that the boot is needed mainly for salt water use. Thanks
