  #1
Old October 26th, 2008, 07:05 PM
MATEY MATEY is offline
Default mercury 40 hp 4 stroke carb
Ihave a 2001 40 hp 3 cylinder 4 stroke. Engine starts perfect, idles and slow speed perfect, full speed perfect. However when trottling from slow speed to full speed engine seems to get to much fuel and chokes. Have to give several quick twists to trottle in oredr to pick up speed. also if reducing speed too quickly engine stops. engine also runs erratically at mid range speed.
Any sugestions.
thanks
matey
  #2
Old October 26th, 2008, 11:17 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Default Re: mercury 40 hp 4 stroke carb
Sounds like you need to pull the carb, strip and clean it..
Have you tried new spark plugs?
Chris.........
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #3
Old October 26th, 2008, 11:37 PM
mthieme's Avatar
mthieme mthieme is offline
I worked on a 2004 Mariner 40hp 4 cyl this summer with a carb problem...had three carbs.
The seat for the needle was nothing more than a thin copper washer. In the uppermost carb, the needle never seated properly causing the upper carb to drip fuel.
I assume it uses the same carb. Someone will correct me if I'm wrong.
Anywho, I didn't think much of this design.
__________________
Nothing is so broken that Government can't make it worse.
  #4
Old October 27th, 2008, 02:24 PM
plugs are new. I read somewhere that there is no adjustment for the 3 carbs.
Does anyone know if this is true. Also was wondering about three screws on small lever attached to each carb. They look like adjustment screws.
matey
  #5
Old October 27th, 2008, 06:39 PM
mthieme's Avatar
That sounds like the idle adjustment.
Is this the only screw you can find?
Look for a screw in front toward the bottom.
This would be your mixture adjustment.
__________________
  #6
Old October 27th, 2008, 06:49 PM
hamit59 hamit59 is offline
Send a message via MSN to hamit59
your right about the carbs that design is not the best I have ever seen.
It makes me wonder about these new engineers. after 3 tries I just had to replace the carb. I couldn't get the new seat to seal off with the needle valve.
__________________
Hamit
BT1 USN ret
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2004 - 40 HP Mercury 2 stroke coconut Mercury & Mariner Outboards 2 July 19th, 2009 09:42 PM
40 HP 4 cyl 1996 2- Stroke Mercury Prop 354v1994 Mercury & Mariner Outboards 1 March 9th, 2007 12:28 PM
Mercury - 40 to 50 HP by changing the carb laybackman Mercury & Mariner Outboards 19 June 27th, 2004 05:08 PM
Mercury 40 hp 4-Stroke Big Foot Good or Bad butlp Mercury & Mariner Outboards 2 February 28th, 2002 03:59 AM
40 hp mercury 4 stroke big city Mercury & Mariner Outboards 1 November 26th, 2001 03:23 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
