Re: gm 305 to new350 swap
What makes you think you need a reman.?
How much money you looking to spend? For only a couple hundred dollars more than the cost of a Rapido reman. You can buy a brand new GM Goodwrench 290 HP crate motor like mine.
Just replace the head-gaskets with composite ones (I used the blue Felpro ones from Autozone), and put some brass freeze plugs in it. Wammo, marine engine!
If you feel like spending a few extra bucks, you can get some Vortec heads to slap on there as well.
It all comes down to what you're looking for.
There is NO difference between a "marine" engine, and a truck engine, except the head gaskets and freeze plugs. Some of the "marine" cams, are the exact same cams they put in truck engines, but if it gives you peace of mind, you can spend another $150 and get a "marine" cam for it as well...
If you just want a simple swap, with a warranty, just buy the Rapido Reman. You'll void the warranty of a GM Goodwrench crate engine by marinizing it...
There are plenty of options out there. It just depends on what you want, how much you're willing to spend, and how much time you want to spend on it.
Oh, and the GM Goodwrench Crate motors were made in Mexico. The "Mexican Blocks" used an iron with a higher nickle content, which makes them a little bit stronger than Canadian and U.S. made blocks. Nothing to write home about though. Any block will do...
