1983 15 hp johnson
Bigred99
I have a problem with the throttle?carb? The engine starts idles and will troll but will not wind up full throttle it still stays at idle (a little more fast idle) but will not wind up or go fast. It was tuned , and has been setting for a while but no gas in carb when stored? It took a while to start and then noticed no full speed. linkage? carb need cleaning ? adjustment? it has work flawless always so am stumpped this time.
CATransplant
Re: 1983 15 hp johnson
Take the cowling off and watch the carb linkage as you twist the trottle grip. If nothing moves, you have a problem with the twist grip or something else in line between the tiller handle and the carb/timing plate.
If everything moves normally, it's probably a clogged main jet in the carb or an ignition problem.
