Have a 1989 Evin V4 which gave me an overheat warning (steady horn) after about 10-15 minutes of running just above idle. Checked both temp sensors using the hot oil method; both appear to operate normally. When I ground the tan wire (from either sensor) with the ign ON, the horn sounds but when I UNground the wire the horn continues to sound. My (Clymer) manual shows a diode in that circuit, but I have no clue where it's located. I'm suspecting either that diode or possibly the horn itself. Unable to find any shorting or chafed wires etc.
Anybody else ever have this problem?
