TonyNoriega
- Jul 31, 2007
- 100
My setup is a dual station, single engine 200hpdi (2001) with the second station on the upper helm, on a 22v Pathfinder.
The lower station has the normal keyed ingnition/start switch and the upper has pushbutton on/off switches. For the engine to be started at the upper station, the lower, main, switch must be on.
My question is: is it ok to leave the lower switch on for extended periods? There are times when the key is on while I'm up in the tower with the motor off and I don't know if it could either damage the ignition system or perhaps use battery energy unneccesarily.
Thanks in advance for your advice.
