I have a 2001 Alpha I Gen II sterndrive which is leaking gear oil. My sterndrive has the gear lube monitor. It appears that the leak is occuring inside the transom but I'm not sure if the gear lube hose is leaking, or if the leak is a result of a bad seal in the drive shaft housing.
The entire gear lube monitor will empty (last time out, ran the boat for 2 1/2 hours and had to fill the monitor twice) even when the boat is sitting. When I unscrewed the vent hole on the outdrive (with the leg in the full trailer up position), gear oil ran out. It seems that I will have to remove the power steering assembly to access the quick connect coupling on the gear lube hose(I suspect the leak is at the connection).
Could a bad O-ring seal in the drive shaft housing be the cause of this leak?
