115 johnson unsure of year
seamoors
hello,
picked up johnson 115; told it was 1987; no tag on bracket, plug on powerhead says R8574898
can anybody confirm the year for me?
thanks,
seamoors
Dhadley
Re: 115 johnson unsure of year
There was no 115 in 87.
Is it a crossflow or a looper? If it's a crossflow are the exhaust plates flat (between the heads) or do they have a hump towards the bottom.
That R number is a serieal number. A dealer can run it for you.
ccnstlr
115 was made 1969-1985 then again starting 1990.
FAQ 17. I don't know what year outboard motor I have. Can you tell me how to find out?
Get the model # from the little plate on the motor's mounting bracket or; on earlier models stamped on the crankcase. Here is a link to the model year guide: "http://www.maxrules.com/ej_contents.html"
seamoors
exhaust plate has a big hump; not sure about crossflow or looper?
thank you
tashasdaddy
the number is a model #, no published, contact a J/E dealer they can tell you.
Dhadley
OK, are the exhaust plates bolted on with a bunch of bolts or is the exhaust and block one casting?
dajohnson53
Can an amateur determine whether an engine is a looper or crossflow just by looking at it?
Dhadley
Yes. A looper does not have any bolt on covers. The crossflows have exhaust plates / covers, intake by-pass covers and water jacket covers all bolted on. (Lots of bolts) The loopers have no covers over the exhaust or intake areas nor a water jacket cover on the heads.
Not to mention the 90* looper is flat out a bigger powerhead.
seamoors
hello again. big bubble exhaust back is bolted on with many bolts (exhaust and block are not part of one casting).
note: i would not be suprised if the engine cover is not original (iow... maybe not a 115?)
Thank you
seamoors
Good Morning,
Any thoughts on what the year is? Recap: V4 CF (bubble back with lots of bolts and jackets on heads); cover says 115 Johnson; VRO (with tag that says ethanol safe).
Tag with model # missing.
Thank you,
seamoors
Dhadley
Could be a 1985 or later 115 which is the same as the 1984 140. The 110 and 112 are the same also.
seamoors
sounds good. i see when purchasing parts, i'm in a pretty wide range of years for a 115 carb rebuild... 1969, 1980-1995
amazing. i'm much happier working on this engine as opposed to the 125 force laying next to the boat now
Dhadley
The carb kits will be the ones for the 1980-95 (from your list).
