  #1
Old October 23rd, 2008, 03:31 PM
Billigan1 Billigan1 is offline
Thumbs down 1996 Mercury 200 EFI Bogging Starving For Fuel
Well this could be a very long story but I will sum it up. Boat it used, great motor for about a month, would not idle high enough to place in gear, it died. Took it to what I though was a reputable shop. They did 3000 worth of nothing to it and had the same problem 2 hours later. Blew the power head, burned 6 and 2 my gues is ran to lean or oil pump died. Pulled engine rebuilt it myself, new everything, done the right way, even reeds. Nice turn out, strted right up. I am on hour 10 of break in. Motor bogging. Switched to external tank, changed water separator, ran like a top for 6 gallons. Did some idle trolling for about a mile worth of no fish and now same problem again on external tank. I am running double oil. Cleaned plugs, ran tad better but running rough no power. 90lbs on fuel pump, regular opening, new pulse pump pushing 4 lbs like it is supposed too. New trigger on rebuild, all 6 are hitting. Clueless here! Running as if plugs are foul, but they are not. Don't want to kill new powerhead, HELP. I understand this motor, I am no expert but understand it, read the manual cover to cover, new fuel lines, so much new, same bug. Any takers?
  #2
Old October 23rd, 2008, 07:05 PM
CharlieB CharlieB is offline
Default Re: 1996 Mercury 200 EFI Bogging Starving For Fuel
First, ensure that the fuel pick up in the vapor separator is clean, no restriction, same with the water filter.
Then take that pressure gauge for a ride and watch the rail pressure as you hit the throttle, ANY sign of pressure falling off shut down and replace the high pressure pump.
High pressure pumps willll always show pressure at idle and light loads, but when the max flow required for high RPM loads, well, it ain't there. And you lean out and melt pistons.
Also double check all hose routing from fuel tank to primary pump, one zip tie too tight restricts flow enough to go lean at WOT.
  #3
Old October 24th, 2008, 05:25 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
I would also check that the fuel lines upstream of the motor are not causing a problem. If you decide to test for this, the below guides may be of help. The guide is most applicable to a carbed motor but I think that the test for fuel line restrictions may still apply to EFIs. At least you can eliminate fuel line restriction as a possibility.
File Type: jpg Fuel Starvation_3_Leak and Vacuum Test.jpg (75.3 KB, 20 views)
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 Mercury 200 EFI rambilt Mercury & Mariner Outboards 5 April 9th, 2008 07:36 PM
1996 Mercury 200 EFI Overheating at idle. vulpine Mercury & Mariner Outboards 3 August 27th, 2006 11:14 AM
1996 200 EFI electric fuel pump bad ?? Bran Mercury & Mariner Outboards 8 March 17th, 2005 05:07 PM
1996 Mercury 200 Efi (High Voltage) GaryDean2 Mercury & Mariner Outboards 7 October 8th, 2003 06:16 PM
1996 mercury 200 EFI Detonation Module Gary Dean Mercury & Mariner Outboards 2 May 12th, 2003 07:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
