  #1
Old October 21st, 2008, 12:27 PM
sledhead26 sledhead26 is offline
Default Bleeding '94 Mariner 115 trim cylinder. Help!
Ok, all or most all of the oil leaked out of my cylinder due to a broken fill plug. Now i read the service manual on how to bleed it and it doesn't help much. The only way i can get the motor to go up is by lifting it after i open the manual release valve which i think just lets air in. It will go down when the trim button is pushed but not up. It has a single lift cylinder with the resevoir/motor attached. Does anyone know how to bleed this type of cylinder. Thanks in advance.
  #2
Old October 22nd, 2008, 10:51 AM
Chris1956 Chris1956 is offline
Default Re: Bleeding '94 Mariner 115 trim cylinder. Help!
Usually you tilt 'em up and let the air bubble out.
On your model, I would leave the manual release set for automatic, and lift the motor by hand, while runing the PTT. Use the manual latch to hold it in the full tilt position, and fill it with trans fluid. Let it set a few minutes, and then cycle it down and up, helping it if necessary. Latch it up and refill. Now let it sit a few minutes and repeat until no more fluid can fit in the resevoir.
  #3
Old October 22nd, 2008, 12:29 PM
I've been doing what you said and the motor still goes down slow and sometimes jerky. But it won't go up at all by itself. I have to pull up on it a fair amount all the way to the full up position. Does it just take a lot of this cycle to get all the air out? Or am I missing something?
  #4
Old October 22nd, 2008, 03:55 PM
It can take some time for the air to bubble out. Leave it all the way up for an hour or so, then refill it, run it down and then up and let it sit an hour again. See if that eventually gets it.
  #5
Old October 24th, 2008, 10:47 AM
I've attempted this numerous times now and I don't seem to be getting anywhere. The motor still goes down slow and won't go up at all on it's own. When I push the button to raise it up it sounds really different than when it's going down. The trim motor is running when the up button is held. It just sounds funny and won't move.
  #6
Old October 24th, 2008, 04:47 PM
krakatoa's Avatar
krakatoa krakatoa is offline
Which service manual did you own? SELOC?
__________________
Boricua 100%
  #7
Old February 19th, 2009, 04:33 PM
GeoRXT GeoRXT is offline
I have this same problem on my '96 125hp. I was told the seals on the cylinder were bad. However, I cannot take it out. Is there a how-to on this?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
94 150 xr6 tilt/trim bleeding down fast. astrobassman04 Mercury & Mariner Outboards 4 August 24th, 2007 09:39 PM
Trim cylinder bleeding cooter2506 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 April 27th, 2007 12:01 PM
bleeding mariner 200 efi trim barefooter Mercury & Mariner Outboards 0 January 4th, 2006 09:32 AM
trim cylinder bleeding jpotter93 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 March 26th, 2004 06:04 AM
bleeding trim cylinder lines worley1 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 March 6th, 2004 09:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
