Re: pitch question
A prop pitched to work at optimum efficency at 4400ft is set to utilise the power output from the motor. At 4400ft the air is thiner with less oxygen than at sealevel therefore the engine would have the fuel air mixture adjusted and the pitch chosen most likely would be a slight decrease from sea level. For instance if you ran a 19in pitch at 4400ft then you would most proberly run a 21in at sea level, so at 600ft the choise might be to stay with 21in.
If in doubt stay with the one chosen to perform at 4400ft since it will obviously work but may use a bit more fuel for the same job.
Ross
