1986 115 hp Yamaha won't idle
My 1986 115 hp Yamaha won't idle; when one shifts into neutral, after starting it, it stops; same is true after it is thoroughly warmed up.
It starts and runs fine with the warm up lever raised; as soon as I lower the warm up lever to a speed where I can shift, the engine stops. The only way I can shift is if , as I lower the warm up lever, I tap the choke button and then quickly put it in gear and accelerate a bit above idle speed.
The other day, after two separate two plus miles runs, and after we had run above idle speed for a few minutes, I shifted into neutral and it died right away.
I am using this boat on a lake on the MN/Canada border, where the air temp is in the low 50's during the day and near or at freezing at night; the water temp is probably in the 40's - this is something new so I am wondering if the cold water or air temp is having some effect - it would seem it shouldn't as there are lots of outboards running here with no problems - carbs were cleaned this summer - so, I need some help -
Thanks -
