  #1
Old October 18th, 2008, 07:20 PM
dungbeetle46's Avatar
dungbeetle46 dungbeetle46 is offline
Default cooling question mercury 650
Hi, new here and I have a problem
Just bought a hartley 18ft cruiser with 1963 mercury 650 outboard.
Motor seems to run fine but the water comin out of pee hole is very low pressure, taking a closer look it has water coming out down the bottom where the rod goes down for engine lock, any ideas why this is.
thanks in advance
  #2
Old October 20th, 2008, 06:32 AM
Default Re: cooling question mercury 650
anyone?
  #3
Old October 20th, 2008, 09:04 AM
Yachtzee Yachtzee is offline
I have several early and mid 60s 650s. A couple of things to think about.
First when you say water is coming out the bottom, do you mean the bottom of the cowling around the engine or the lower unit? Low pressure from the teltale can mean a worn impeller, they need to be changed periodically especally if the motor has sat unused for a long time.
If water is comng out the cowling, maybe you have a split hose from the teltale to the fitting on the block.
Or, possibly the low pressure and the leak is the water jacket cover over the exhaust is leaking. I have three of these motors and all three have had holes eaten clear through the exhaust cover. I ran the one for a long time with water squiting out of it and it never seemed to do any harm. However, one other one had a hole eaten not just through the outer cover but straight through the inner jacket too. It was squirting water straight into the exhaust port of #4 cylinder.
The bolts that hold the cover on are dang near impossible to get out without breaking.
If you find a leak ther let me know I'll tell you how I fixed up mine.
  #4
Old October 20th, 2008, 10:15 AM
thanks yachtzee, the water leaking is comig from the transom end of the join between the lower leg and above, I think this is called the cavitation plate, there is a small rubber seal here where a rod comes out and moves the lever that locks the motor in the full down position, it seems to be leaking somewhere near that, is the water hose near there and could it be as simple as a hose has come loose or has a hole in it, I dont have a service manual and cant find one in Australia so dropping the lower leg off is scaring me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1974 Mercury 650 - tune-up question fishysmell Mercury & Mariner Outboards 5 September 20th, 2008 10:32 PM
Question abt 1968 Mercury 650 golfrbob2 Mercury & Mariner Outboards 2 July 21st, 2008 09:20 PM
'69 Mercury 650 cooling problem PuckHog Mercury & Mariner Outboards 4 July 5th, 2005 09:31 AM
Tach question for Mercury 650 JollyBFD Mercury & Mariner Outboards 1 June 7th, 2005 12:47 PM
1974 mercury 650 cooling problem? albert71 Mercury & Mariner Outboards 2 July 17th, 2002 03:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
