  #1
Old October 18th, 2008, 12:58 PM
HaloStatue HaloStatue is offline
Default Yamaha 150 - electrical harness bad?
All...
I have a 2000 Yamaha 150 outboard (model # DX150TLRY - from the port side transom plate) on my Gulf Coast 20'. My water pressure gauge went out, then my bilge pump quit. While I was idling along (at night), I smelled something like electrical burning. Moderate smoke was coming out of the bilge area and from under the center console. When I turned the accessories off, the smoke cleared an the smell went away. The motor ran fine.
The next day, when I could see into the bilge I turned the accessories back on and found the source of the smoke.
I don't know the name of it, but it appears to be a main electrical harness. It is a squarish, black harness with two 1-inch square fuses plugged into it. It was smoking and the fuses were melted. It has some serious corrosion in it and will need replacing.
I'm assuming that the harness is bad and may be the cause of all of my electrical problems. What I'd like to find out is:
1. What's this thing called?
2. How do I diagnose it to determine that the "harness" is the problem or to track down the real culprit?
3. Where are the best places to find replacement "harnesses"? Is it a Yamaha part or are there other providers?
4. How big a deal is this to replace?
I don't mind troubleshooting, either through a trial and error method or using a multimeter. I just need some direction.
A second part to this is that I was thinking about running new wiring from the bilge to the console (fuse box), anyway. I just don't know how big a deal that is, so I haven't begun. Any tips on that would be appreciated, too.
Thanks,
Halo
  #2
Old October 19th, 2008, 10:35 AM
Default Re: Yamaha 150 - electrical harness bad?
Okay, it turns out that this is the relay switch to my jack plate. It was disconnected when I had my powerhead replaced. Something is wrong with the jackplate pump/motor and so the shop never reconnected it.
I don't know why the switch melted down, though. I'm still trying to work that out.
And I've pretty much answered my own question about the wiring job, too.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'02 Yamaha 150 2 stroke- miss firing/bad gas? tyjo Yamaha & Suzuki Outboards 1 July 21st, 2008 11:02 PM
Yamaha 150 Boat Harness esteym Yamaha & Suzuki Outboards 4 November 8th, 2005 05:19 AM
35hp electrical harness boatsalotjay Non-Repair Outboard Discussions 2 May 12th, 2004 12:31 PM
Yamaha 150 HPDI - good or bad? brianwhart Non-Repair Outboard Discussions 0 August 20th, 2003 06:52 PM
Flushing adapter on 150 Yamaha...good or bad idea BTurville Yamaha & Suzuki Outboards 8 January 9th, 2003 01:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
