cowl gasket for 72 Johnson 50 hp
swimmin' for shore
I'm trying to locate the above part. The hood gasket, or cowl gasket, or whatever you want to call it, that goes around the base of the hood and seals water out of the engine compartment. Iboats doesn't have it. Ebay doesn't have it. Does anyone know where I might be able to find this online? Thanks.
tashasdaddy
Re: cowl gasket for 72 Johnson 50 hp
a lot of people take fuel hose and split it, slip it on. with some contact cement.
swimmin' for shore
May have to try that, TD. I've contacted every online store I can find, and no replies yet, though I just did it yesterday, so I may get some feedback yet. In any case, what's happening is that with the gasket shot, the hood is sitting down on my motor, and it's spinning against the fiberglass hood, causing lots of shavings in there. I doubt if it's hurting the motor, but I can hear it clicking against the hood when it's spinning, which drives me nuts. Just the little things that come with an older motor. I've dealt with a lot worse. Thanks for the reply.
jtboats
Hello
I have the same problem trying to replace those gaskets ..
I'm going to order one for a newer engine with luck it will fit they look the same I don't care if its longer...Joe
