50hp HAVING PROBLEM WITH GETTING PARTS
KES53
I HAVE A 1986 BAYLINER CAPRI WITH FORCE 50hp CHRYSLER ENGINE. MY PROBLEM HAS BEEN LOW POWER NO GET UP AND GO.FIRST THOUGHT WAS GAS MIX BUT FOUND COIL CRACKED AFTER PLUG KEEPED FOULING OUT.I FOUND A USED COIL THAT WAS OVER 20 YEARS OLD PUT IT ON RAN GOOD ON HOSE THEN PUT IN WATER SAME THING PLUG FOULED OUT NO REAL POWER.THEN FOUND COIL CRACKED AGIAN.IM HAVING A LOT OF TROUBLE FINDING A PLACE TO USE MODEL# AND OR SERIAL# TO GET PARTS I DON'T HAVE A MANUAL OR PARTS BOOK TO THIS MOTOR. SO IF ANYONE HAS ANY INFO OR SUGGESTIONS I COULD USE TO GET THE BOAT OUT ON THE WATER?PLEASE FEEL FREE TO LET ME KNOW ANYTHING OF HELP GOD BLESS ALL! MODEL#557HC, SERIAL#3272.
jerryjerry05
Re: 50hp HAVING PROBLEM WITH GETTING PARTS
Sounds like you need to do a compression test.Then look for parts.Jerry
bman1bpm
Iboats has a lot of parts for the force motors.
this site also has most of the parts
http://www.maxrules.com/
there is a marina in annapolis, md called fairwinds marina that has EVERYTHING! google search them they'll mail parts if you're not nearby
roscoe
Your motor was made in 1971.
maxrules website is good for the older Chryslers.
KES53
Roscoe Thanks For Reply But How Did Come To The Year?
KES53
I've Been On Maxrules Not Found Coil That Looks Like Mine. The Compression Checks Good.
KES53
1971 55hp MOTOR CAN ANYONE HELP TO DETERMINE WHAT COIL I NEED FOR THIS ENGINE I DON'T KNOW IF IT HAS POINTS OR NOT DONT'T HAVE BOOK ON IT!MAY GOD RICHLY BLESS YOU ALL WITH THE LOVE OF HIS SON JESUS!
