  #1
Old October 17th, 2008, 07:29 PM
Rick. Rick. is offline
Default 1971 Evinrude 4 HP. seafoam but no smoke.
Hello. I did a seafoam treatment on my motor yesterday. I made a batch of seafoam/oil/gas mix, sprayed the cylinders the night before and started it up on the lake yesterday morning. I let it warm up to op. temp. let it sit for 15 minutes started it up and still no smoke. I had it going from idle to wide open. Does this mean I don't have a carbon build up or was the seafoam expired? When I say no smoke I mean only the normal amount. I also did a 4 HP Johnson at the same time with the same, no smoke, result. Thanks, Rick.
  #2
Old October 17th, 2008, 07:51 PM
WTL WTL is offline
Default Re: 1971 Evinrude 4 HP. seafoam but no smoke.
I didnt know seafoam can go bad. How much did you put in the gas? Sometimes I pour some down the throat of the carb too and that should get it smoking.
  #3
Old October 17th, 2008, 08:20 PM
iwombat's Avatar
iwombat iwombat is offline
You probably put most of the extra smoke in the lake. That 4hp isn't going to burn up a lot of fuel anyway and it may be hard to notice the extra.
  #4
Old October 17th, 2008, 08:28 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
i would say you have clean running motors. congrats.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old October 17th, 2008, 08:34 PM
ezeke ezeke is offline
How long did you actually run the motors on the SeaFoam mixture?
  #6
Old October 17th, 2008, 09:11 PM
I ran the motors for 20 to 25 minutes each. I used the FAQ suggested ratio of 16oz. per 3/4 of a gallon. Now that I think of it I used an Imperial gallon which is slightly more than an American gallon. That would of left the mix a wee bit leaner. Rick.
  #7
Old October 17th, 2008, 09:42 PM
If there were carbon build-up that would have burned it off. I think TD is correct.
  #8
Old October 18th, 2008, 05:55 AM
keep maitaining those motors the way you have, they will last for ever. but it will never hurt to seafoam again, in a year or 2. just maintenance.
__________________
FLORIDA GATORS
TEBOW Country
  #9
Old October 18th, 2008, 11:56 AM
Well the seafoam must have done something. The night before I did a cold compression check and found both cylinders were at 85lbs. cold. Last night I checked them again, cold, and found the top @ 97 and the bottom @ 95. This is the first time this motor has seen a lake in several years so in spite of the lack of smoke the seafoam ( or just a good run) did improve the compression by a lot. Rick.
  #10
Old October 18th, 2008, 08:57 PM
wilde1j wilde1j is offline
You had stuck rings from carbon build up.
__________________
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1971 Evinrude 4 HP Rick. Johnson & Evinrude Outboards 1 September 21st, 2008 06:41 PM
1971 Evinrude 125 hp Nico Johnson & Evinrude Outboards 3 May 7th, 2007 10:54 PM
1971 Evinrude 50 hp james28144 Johnson & Evinrude Outboards 3 April 18th, 2007 11:12 PM
1971 evinrude 50 hp sergio rodriguez Johnson & Evinrude Outboards 4 January 3rd, 2007 09:22 AM
Is my 1971 Evinrude 55 or 60 HP? RuggedCoast Johnson & Evinrude Outboards 6 August 24th, 2006 03:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
