eavega
- Apr 29, 2008
- 1,377
Hi all. I have a FD-22 outboard that I have tried to bring back from the brink of death. I took it out to the lake today to test it out and to see how it pushes my boat. I ran into an issue and was hoping for some guidance with troubleshooting, as neither the OEM service manual, nor the Seloc outboard repair manual are very good at troubleshooting.
The primary issue is that the motor is not cooling at all. I ran it for less than three minutes (at close to WOT to be sure), and in that time the heads were too hot to touch, and would sizzle a drop of water on it. There is water coming out of the back (no pee hole in this old girl), so I would assume the impeller is working well enough to pump water. I can't attest to the specific condition of the impeller, as I haven't replaced it. I was told by the person I got the motor from that the impeller had been replaced two months ago. When working on the motor (I did replace the ignition components, among other things) I could hear the impeller blades squeaking against the pump housing when I turned the drive shaft, so I assumed it was good.
So, this is the troubleshooting path I am going to follow, please tell me if I have missed something, or if I have things out of order. My basic goal is to start at the least complicated/least expensive components and go from there.
1. Check impeller for wear or damage.
2. Check the usual components for water pump rebuild; o-rings (driveshaft and the two that go on either end of the exhaust housing spacer) and the grommet.
3. Check thermostat for proper operation.
4. Pull the head and inspect the water passages to look for blockages or build-up.
Again, if there is anything I can do short of pulling the head, please let me know. The powerhead has great compression, and I would really hate to mess with that if I didn't have to.
Also, if I have to pull the thermostat, do I need to replace the gasket? I would assume yes.
Thanks in advance for your help.
Rgds
Eric
Rgds
Eric
