My boat has been in storage for the past year while I was activated to military service. I recently returned home and got the boat out of storage. The Johnson 1995 100 HP is a V-4 with VRO system and it has a V-6 lower unit. It is a commerical 100. Anyway, the overheat alarm has tripped off after about 3 minutes of less than 2000 RPM. It has never done that before. The boat was stored in an area where the weather was below freezing on occasion. I thought I flushed all the sea water out. Prior to the engine check, the water pump was examined and it was functional. The alarm went off when I did a engine check while on the trailer. The eninge was "spitting" just fine. Would the thermostat be bad or is it one of the heat sensors? I did not see any water leaking from the power head. I did not see any loose, broken, or frayed wires so shorts may be out. Any ideas?
