Hi Hope someone can help me with a controller problem, I?ve got a 2004 mercury 115 hp EFI 4 stroke engine with a controller, not sure which model it's the basic side mounted black box type, free with the engine so I?ve been told.
Ok hears the problem when the controller is engaged from neutral in to forward I have drive or thrust whichever?.From that point thru I guess three quarters there is nothing just a lot of play ,then I get a whole lot of thrust all at once, it?s the same in reverse only nearly throttled out completely before I get any response, ( not so good for controlled manovering ). Boat just back in the water after being at a mercury Agent for a service and the rest allegedly , after a lota cash he tells me that this is normal in that model of engine ? hard to believe? and not much can be done. see the thing is he said the only thing he could find out of place was the cable not in the right connecter it had been connected to the below 75hp connector ??. I?m confident that just after launch the problem seemed to be fixed only to find that the next outing it was back to the same problem. If anyone can help it will me much appreciated.
