  #1
Old October 16th, 2008, 06:59 PM
mjxlange mjxlange is offline
Default 2003 Yamaha 150. will not idle
2003 Yamaha 150. will not idle or run at low RPMs give it some gas or choke it and it smooths right out. I took the cover off yesterday and noticed that extra gas leaks out of the carbs. Could it be that it is getting too much gas and if so how do I fix it. I am pretty handy once I know what the problem is so fixing sould not be an issue.
  #2
Old October 17th, 2008, 11:12 AM
gsyfishy gsyfishy is offline
Default Re: 2003 Yamaha 150. will not idle
If the carbs have never been cleaned, that is most likely your problem. Most motors will open up the high speed jets when you accelerate, but if the low speed or idle jets are gummed up, you'll need to clean em up.
I believe somewhere on this forum, there is a step by step to this procedure.
  #3
Old October 18th, 2008, 12:01 PM
rodbolt rodbolt is online now
you having multiple issues,one is some leaking needles the other is plugged pilot fuel jets.
by tapping the choke your forcing the engine rich bypassing the pilot fuel circuits.
clean the carbs carefully and if the lift pumps have not been replaced in the past 3 years go ahead and replace/rebuild them.
always remember how and why the systems work.
you trouble shot your own issue.
if it was a rich run condition tapping the choke would further enrich the mix causing a shut down and flooding.
not what your describing.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Winterizing a 2003 Yamaha 150 HPDI Bob Gale Yamaha & Suzuki Outboards 0 August 26th, 2008 09:38 AM
Low water pressure at idle...2003 Yamaha 150 hp vmax. Bassin46 Yamaha & Suzuki Outboards 8 January 14th, 2008 10:25 AM
2003 yamaha 150, no reverse gtl Yamaha & Suzuki Outboards 1 June 24th, 2006 02:57 PM
2003 Yamaha 150 hdpi MikeKG Yamaha & Suzuki Outboards 11 October 22nd, 2004 03:10 PM
2003 Yamaha 150 MikeKG Yamaha & Suzuki Outboards 8 February 29th, 2004 05:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
