I have an 04 150 EFI Merc. and a striped down 01 block. Will the PCM from the 01 work with the 04?
O overbudget Recruit Joined Sep 1, 2008 Messages 2 Sep 1, 2008 #1 I have an 04 150 EFI Merc. and a striped down 01 block. Will the PCM from the 01 work with the 04?
achris More fish than mountain goat Joined May 19, 2004 Messages 27,468 Sep 1, 2008 #2 Re: PCM Crossover Get the serial numbers from each engine... Look up the part number for each PCM on any one of the on-line parts ordering systems. If the numbers are the same, yes it will work, if the numbers are different, then no it won't... Chris...........
O overbudget Recruit Joined Sep 1, 2008 Messages 2 Sep 1, 2008 #3 Re: PCM Crossover Thanks i will give it a shot.
