Re: Tige Tranny Problem?
Not a velvet drive . . . is there a
V-drive (not Velvet drive despite coincidence . . . ) in front of the Velvet drive or is this boat a direct drive. If the engine is in the middle of the boat, it is a direct drive configuration. If the engine is in the back with a sun-lounge on top, then it is a V-drive. If it is a V-drive, then it is possible the problem is not in the transmission, (velvet drive) but in the V-drive which changes the direction of the output shaft from forward to back.
Basically, most wakeboard boats have the engine in the back to help create a bigger wake, and make for a more comfortable (larger) passenger area. The engine is installed backwards and the output shaft goes from the transmission, into a device that reverses the direction kinda in a V . . . and then prop shaft comes out of it. You could have a failure of the V-drive and still have a good transmission and what you describe could happen. That's why I want to know if the output shaft of the Velvet drive (attached directly to your engine) is turning when you put it in gear. Since the propeller is there, if the transmission turns and the propeller doesn't then we have probably isolated the failure to the V-drive unit. If you have a direct drive, despite the condition of your fluid, you have probably had some sort of failure in your transmission. I guess this could be a simple cable issue, but the fact you heard a "bang" tells me that it is not . . .
