4-Cycle oil in 2-cycle outboard
canesfan
I mistakenly put 4-cycle 10W-30 Pennzoil "Premium Outboard" marine oil into 12 gallons of gas for a 2 cycle Johnson 90HP outboard engine. Should I cut my losses and drain the gas tank, or will permanent damage result if I ran the engine on this fuel mixture? If I run the current mixture, would it make sense to add the appropriate 2-cycle oil to the tank?
ondarvr
Re: 4-Cycle oil in 2-cycle outboard
There was a time when that's all we used, just 30W motor oil. I think if it were me it would now be lawn mower fuel.
Silvertip
Honorary Supreme Mariner
By all means do not use it except in a four cycle engine such as a lawn mower or your tractor. That oil is not designed to be burned. 2-stroke oil is.
tx1961whaler
You didn't hurt the motor, but don't run it in there. That is a multi-grade, detergent motor oil that is not good to burn in a two cycle. I used to use straight 30 weight, non-detergent motor oil for many, many years, but newer oils are supposedly much superior to using straight oil, which is not designed to combust.
kenmyfam
Not a good idea. Do not throw it away though, use it in the lawn mower etc as suggested.
LubeDude
You "PROBABLY" (Therefore do not do it), could get away with it in a pinch if you do not run the engine hard! I would do like suggested above and run it in your truck or lawnmower!
The oil could separate as regular oil is not designed to stay in suspention like TC-W3 oil is. This would likely be the main issue that I would be leary of!
