77Glastron
- Aug 31, 2008
- 1
i hvae a 77 mercury 1150 115 hp that has no power in the water. if i tilt the motor up and get the prop out the water it revs up but as soon as it gets in water it drops to an idle. at WOT it is barley moving on the water. i was pulling a tube at wot when it started this and i removed the hood and the screws for the ignition where vibrated lose and backed out! any ideas what to look for? could the ignition be bad only under a load???
